Why is the hour display set to 19 when I run the attached VI
Why is the hour display set to 19 when I run the attached VI?
Thank you.
(2,747 Views)
Accepted by chuck72352
The Seconds to Date/time function reverts to 12/31/1903, since UTC is false.  Set the boolean to TRUE (UTC)
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,739 Views)
Thank you.
(2,725 Views)
Are you in US Eastern Time?  This looks like an offset due to time zone (EST is -5 hours).  Setting the UTC constant to TRUE will fix that.
(2,724 Views)
Yes EST, and changing the constant to "true" did fixt the issue.
(2,715 Views)
