Write data into an excel file "only one time"
Hi, I’d like to write selected data to an Excel file.
I want to write the data only when I press a button, so I created a case structure with a button that triggers the write action.
However, since this is in a for loop, the data gets written multiple times by the time I finish pressing the button.
How can I ensure the data is written only once?
One solution might be to increase the loop time so I have time to release the button, but is there another way to achieve this?
(798 Views)
Accepted by Alexb91
Hi Alex,
Set the button to a latching "Mechanical action" mode.
Learn about the different possible "Mechanical action" modes for buttons and their use cases!
(794 Views)
Thank you very much for your help!
I just saw a solution you wrote for someone in 2006, almost 20 years ago.
I don't know how many of us would have managed without your precious help.
I wish you all the best.
(775 Views)
