Write to spreadsheet file common path dialog
Hi
I tried to remove visa bytes at serial port. I put XY graph but I am getting only 1 value. Please modify it if possible and send me. It would be very helpful for me. I am very new to labview so I donot have idea about shift registers.
Message 21 of 24
(814 Views)
Hi usakshi,
try this:
And put a command into "write buffer" to trigger a device reply…
Message 22 of 24
(807 Views)
I have changed at the serial port. Please help me at graph. I am attaching the .jpeg file also. There I am getting point instead I want a linear/wave form of graph. It would be more helpful if you send me .vi file
Message 23 of 24
(798 Views)
You discovered the Express XY Graph. You have it configured to Clear data on each call. Just double click on it to see this.
Message 24 of 24
(791 Views)
