Writing a number to TDMS
I don't know how to do that. I am not sure that I inderstand.
Message 11 of 28
(1,965 Views)
Can you just change my subVI?
Message 12 of 28
(1,962 Views)
Accepted by miki90
http://www.ni.com/gettingstarted/labviewbasics/environment.htm#Block Diagram Nodes
I would recommend looking up some LabVIEW basics.
Attatched is a VI where I cleaned it up and allowed it to accept a single double value to write.
Message 13 of 28
(1,960 Views)
Where was my mind...I created a default control on the input of TDMS write instead of making my own control, and then link it to the input. Thank you so much!
Message 14 of 28
(1,954 Views)
One more thing, and I am done with my project: I want to make an event to interact with stop button, and when someone wants to stop the program, the dialogue "Are you sure you want to stop the program?" occurs. And of course YES and NO options. I tried it in several ways, but when I put the stop button from the while loop into event case structure, program stops working. No signal aquisition. I tried with Two button dialogue, but problem with aquisition still exists. Do you have any solution?
Message 15 of 28
(1,942 Views)
Can you post your code?  There's a 1,000,001 ways to mess that up.  And I'm sure I've done half of them.
Message 16 of 28
(1,935 Views)
Again please look up some LabVIEW basics information.
http://www.ni.com/white-paper/3331/en
It is likely you have no timeout so you wait forever for the button to be pressed and won't take any readings until an event is generated.  Adding a timeout case is a patch to an already bad layout.  One should not need to be polling anything in a program of this size.
Message 17 of 28
(1,933 Views)
It is the same program I attached above. I also tried to put a timer,but it shows me some error. A message is: "You must provide a case to handle the Timeout event if the timeout input is wired."
Message 18 of 28
(1,930 Views)
Well did you try to provide it a timeout case?  One is made by default when you put down an event structure.
Message 19 of 28
(1,927 Views)
I tried, but it doesn't work the way it should work. I have materials and I read about events, but nothing solved my problem. Frequency analysis are stopping after few seconds,and then I cannot stop the program with the stop button on the front panel. I have put a constant value of 1000 in the timeout case,just for trial.
Message 20 of 28
(1,918 Views)
