Writing a number to TDMS
Hi Miki,
I think it really might be a better idea to repost your code with the event structure you added. Events can be tricky when encountered first and it might be much easier to troubleshoot with the code attached 😉
Jano
Message 21 of 28
(1,122 Views)
Thanks for the response Jano! Here is my code. If you cannot use a code without subVI's, I will attach them too.
Message 22 of 28
(1,116 Views)
I looked through your code. Basically - when you hit the "Stop The Program", you check for "Stop Reading Value" and get into an idle loop. To simplify things, I would suggest to try the code like this 😉 Also, feel free to use the value 0 for the timeout - anyway rest of your code will be timing the loop.
Jano
Message 23 of 28
(1,110 Views)
With your code my program is working, but when I stop the program, it doesn't show the message from the dialogue. Do you know what may be the problem?
Message 24 of 28
(1,101 Views)
If you press the normal stop button, the event will not be triggered.  What you can do instead of the OR is to add the stop button:value change to the event case you already have written for the stop button in the cluster.  Then either button changing values will have the same effect.
Message 25 of 28
(1,098 Views)
I almost succeeded. I made a two button dialogue with a message "Are you sure you want to continue?", but program stops working both on Yes and No. How can I make the program to continue working when I press No button?Here is my code again.
Message 26 of 28
(1,094 Views)
I think this is actually what you want.
Message 27 of 28
(1,085 Views)
Almost perfect! There is one thing that I do not understand. When I press the stop button,dialogue occurs,then I click No .After this, I press the stop button one more time and then Yes button, but program doesn't stop totaly,only aquisition, so I must press the stop button one more time to completely stop the program.Do you have any idea why this occurs?
Message 28 of 28
(1,080 Views)
