Writing characters to text file to convert the data into image
Hi mike
Thankyou
Message 21 of 31
(1,563 Views)
Message 22 of 31
(1,563 Views)
Muks
Please attached your code as .VI for labview 8.5
Message 23 of 31
(1,559 Views)
Hi Hasan,
sorry don't have it anymore.
But you should be able to program it from the image. The only thing you should know is, that the string constant is in "Code Display" Mode.
Mike
Message Edited by MikeS81 on 04-13-2010 10:15 AM
Message 24 of 31
(1,558 Views)
Message 25 of 31
(1,554 Views)
Mike
 😞 how can I search the Sub VIs present in image? how can i know them by their name :S
please tell me the 2nd component's name which is immediate after Open/Create/Replace File VI
thanks
Message 26 of 31
(1,553 Views)
Set file size. Inside advanced file functions
Message Edited by muks on 04-13-2010 01:52 PM
Message 27 of 31
(1,549 Views)
Thankyou Mike and Muks
Let me try with these codes. will letyou people know after a while.
Message 28 of 31
(1,547 Views)
Mike
your code is working.... What I am doing is writing the spread sheet file of values that are coming in through com port. I have attached the file, but your code is not working for this file. what are the mistakes? how can i avoid "tab" delimiter? Please tell me the mistake that i am doing :S
Message 29 of 31
(1,522 Views)
Hi Hasan,
change "\s" to "\t".
Mike
Message 30 of 31
(1,519 Views)
