Writing to a single serial port with multiple VI's in LabVIEW
@RAMASG wrote:
Appreciated your earlier reply.
myRio VI is still not reading the data from Computer VI.
Shall you please enlighten the com port selection in both VI.
This sounds like a hardware problem.   Both the PC and myRIO are DCE data communications Equipment.   You need the right cable to make it work .
Message 11 of 16
(1,044 Views)
What kind of cable are you using?
Is it null modem or straight through?
Message 12 of 16
(1,044 Views)
Thanks for your reply.
Please find enclosed the USB cable (Item 4) connected to myRIO & computer.
It is original cable come with myRIO. Please advise. Thanks.
Message 13 of 16
(1,029 Views)
You've completely changed up the story here!
While a USB cable is "serial" in that is stands for Universal Serial Bus, it is not the same thing as a serial port.  You said you want multiple VI's talking to a serial port which implies VISA and RS-232.
That  USB cable is not a serial port.  It provides a special communication means between your PC and the myRIO.  You need to look into examples and tutorials on how to program a RIO device.  Don't even bother to look at anything related to serial ports.
Message 14 of 16
(1,025 Views)
Thanks for you clarification.
Shall you please advise serial cable to buy... which connect computer and myRIO for data transfer
https://www.ni.com/en-us/shop/category/cables.html?productId=118841
Message 15 of 16
(1,019 Views)
No.  I am advising you to learn how to program the myRIO.  It is a part of an environment that has your host computer, a real-time computer running on the RIO, and the FPGA.  LabVIEW already has examples on how those parts can communicate with each other.
Message 16 of 16
(1,003 Views)
