XNET Frame Sniffer question - best way?
For the record, here's a timing test applied to three different ways of doing it:
All cases have 1000 frames, each with a random one of 5 identifiers.
CASE 1: 12.1 uSec
CASE 2: your SORT idea -  58.6 uSecCase 2.PNG
CASE 3: Chunk-at-a-time 13.6 uSecCase 3.PNG
Steve Bird
Culverson.com
LinkedIn
Message 11 of 13
(894 Views)
Thanks for benchmarking it. I forgot that the timestamp is the first element - you're right, creating a new array of IDs removes any advantage sorting might have (and, of course, I could be completely wrong that sorting is worthwhile anyway).
EDIT: removed suggestion to use a single pre-allocated array. That approach does not work here because it forces Search 1D Array to search through a much larger array (even though most of it is unused) each time.
However, I have an idea that may be even faster: use variant attributes. Attributes are stored in a tree so searching for an existing element is fast (no need to compare every single element), and it automatically removes duplicates too! See image below:
EDIT: I benchmarked this. For 2000 elements, the build array and variant approaches are similar. For a 50000 element array, the variant approach is 10x faster (1s for build array, 0.1s for variant). For a small array (a few hundred elements), build array is faster, although the absolute difference in time is pretty minimal at that point.
Message 12 of 13
(889 Views)
In case anyone is curious, here's a pre-allocated array approach that is as fast as (or marginally faster than) build array in a loop:
And that's enough playing for me today. My benchmark VI is attached in case anyone else wants to play.
Message 13 of 13
(881 Views)
