[XY Graph]Cursor legend difference between LV 7.1 and 2009
Hi all,
recently I am working on having software done in LV 7.1 renew with 2009.
And I have such problem, that with the old version on cursor legend there were options for cursor to be snapped to plot or free-run etc ( it was possible to do that in runtime) So that user could do that without any code added to handle that. Am I doing something wrong with graph settings ? or that functionality has been removed ? I attach a file with a area of my interests 🙂
Regards
PacHOOk
PacHOOk
(3,086 Views)
Accepted by pachook
I think you will be interested in reading the following thread:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=458099
(3,080 Views)
Thanks Ray for your reply, I tried to look for the some of key tags of my post, apparentlly I did not do it properlly. Anyway I looks like without some written (drawn ? ) solution you cannot make it.
PacHOOk
PS Maybe it should be partially-solution option 🙂
PacHOOk
(3,071 Views)
Hi PacHOOK
The way I read your original post, it sounds like you think you have to use code to change the way the cursor locks to different plots. If that is the case, then things aren't as bad as you think. You can still manipulate the cursors at run time Just right click on the cursor box, here you can create (free or snap) or delete cursors, change plots they snap to, and change all of the the cursor attributes.
Ian
(3,063 Views)
The biggest problem was /is with having the ability to have the cursor free or snap to plot. You can do it in a software way but not with the build in functionality.
Well thanks for help too.
PacHOOk
(3,056 Views)
