XY Graph => to put array of string to X scale .
How i can to put array of Strings on the X scale on the XY graph .
For example I have two tables of the same size one which represents the axis Y and the other that represents the axis  X (array of strings).
I can do this?
thank you .
Message 1 of 18
(6,853 Views)
If you mean you want to have non numeric values for your markers on the scale,
then as far as i know that is not possible directly with the charts/graphs.
There are properties regarding the markers, but for me the Marker.Text property never does anything and the help seems to not have this option listed.
Perhaps someone has a suggestion on how to build this feature yourself,
but i presume it is involved.
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 2 of 18
(6,833 Views)
Then I can not put this data in a XY graph as it is presented in the picture?
Message 3 of 18
(6,822 Views)
yes it is possible, because you can use timestamps for the x-axis which can be formatted as you suggested
will attach a snippet later
Message 4 of 18
(6,813 Views)
Accepted by Sarah_LAB
here we go:
Message 5 of 18
(6,810 Views)
Thank you alexderjuengere,
Can you give me please the VI of this solution i don't find some functions?
Thank you .
Message 6 of 18
(6,780 Views)
I  get the date, but they not show up on the date cluster?
What is the problem?
Message 7 of 18
(6,774 Views)
the picture I attached is a snippet: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PkCAI&l=en-US
- it's actual LabView Code you can use!
you have to change the graph's x-axis properties as shown in the screenshot
Message 8 of 18
(6,766 Views)
I had already changed the properties!!!
Message 9 of 18
(6,757 Views)
attach your actual .vi, but make sure it got proper default values for the date-array saved
Message 10 of 18
(6,754 Views)
