XY graph collecting data
I don't cluster that often, is this the right way to do it?
The reason I tried to explain is maybe better to see in attachment.
Koen
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 11 of 14
(470 Views)
Accepted by KoenR94
Hi Koen,
you should name the cluster elements (and creating a type definition from the cluster is a good idea too)...
Clean up the VI:
- use ctrl-U
- remove all those local variables, they aren't needed
- there's a lot duplicated code in the VI, you can make it much leaner...
Message 12 of 14
(467 Views)
Hi gerd,
Did some serious redesign (in my opinion) like you said.
Do you mind having a look?
Koen
Message 13 of 14
(458 Views)
Great that you helped me alot!
Finnaly found my initial problem, the wrong connection kind of problem..........
Koen
Message 14 of 14
(454 Views)
