Xilinx Options in FPGA Target Properties not available
Hello Everyone......I have a little problem.
I can not get Xilinx Options under FPGA Target Propoerties to change the synthesis optimization goal to area instead of speed in LabVIEW 2012. Please let me know the cause and solution of this problem.
Thank You.
(3,608 Views)
chiks,
What FPGA target are you compiling for?
Nick C | Software Project Manager - LabVIEW Real-Time | National Instruments
(3,595 Views)
I am compiling for Compact RIO - 9073.
(3,577 Views)
Accepted by chiks
chiks,
Interesting, are you looking in the correct place for the compiler options? Compiler options aren't going to be located under "FPGA Target Properties" as you mentioned previously (sorry I missed this in your first post), rather those options are located under the "Xilinx Options" category when you create an FPGA build spec for compilation.
Right-click on Build Specifications » New » Compilation, then select the Xilinx Options category and you should see a window like this.
Can you confirm that you are looking in this location?
(3,564 Views)
Thank you sir for your valuable reply. I was looking at wrong place. Now I find it under build specification. Thank you again.
(3,555 Views)
chiks,
No problem, best of luck with your application!
(3,551 Views)
