a question about "for loop"
Bonjour
the problem I try to solve refers to a "for loop" which i try to stop
whenever i press a clear button.
I other words, I have a "for loop" that executes a number of task that last
about 30minutes.
the problem is, that I have no idea about how to quit such loop before the
number of iteration is reached
Thank you in advance for your help
Regards
Gerard
Gérard Férini
Switzerland
(2,727 Views)
Hi Gérard,
you have two main options....
either replace the for loop with a while loop (N needs to be determined programatically) or place the contents of the FOR loop in a case statement, leaving one case empty. By pressing a button linked to the case statement, the calculations for the remaining iterations can basically be skipped. The current iteration will still execute to completion though.....
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,727 Views)
Thanks Shane for your reply. As a matter of fact, I'm going to choose the
first option you mentionned hereby since I think
it's the best option.
Nice of you to have answered
Regards
Gerard
Gérard Férini
Switzerland
http://home.tiscalinet.ch/gferini/
"shoneill" wrote in message
news:50650000000500000026770100-1079395200000@exchange.ni.com...
Hi Gérard,
Hope this helps
Shane.
(2,727 Views)
