acceleration to displacement
Hi
I have an acceleration signal
I can integrate it twice using Labview VI as shown in the attached file in order to find out velocity and displacement signals.
But how do I calculate the INITIAL CONDITIONS for velocity and displacement????
And how to include such initial conditions in the VI
Thanks in advance
Message 1 of 34
(9,620 Views)
You can't calculate an initial position or an initial velocity.  You have to define them.  Do you want to assume your object is as a position of x=0 and a velocity of zero when you start acquiring data and integrating it?  Or do you want to assume it is at a position x0 and/or already moving at a velocity V0 when the acquisition starts.
Message 2 of 34
(9,616 Views)
Hi ...thanks for reply... so nice of you
I got your point....I want to define the initial condition.
My acceleration, velocity and displacement are 0.1, 0.2 and 0.3 at time t=-1 seconds
Please tell how to integrate this information into the INTEGRATION VI shown in the attached file
Have a nice day
Message 3 of 34
(9,589 Views)
Hi Sehgal,
get rid of the ExpressVI, use "real" VIs/functions from the palettes instead and you will be able to supply start conditions to your integration...
Message 4 of 34
(9,569 Views)
Thanks but how to set the initial condition such the CONSTANT OF INTEGRATION becomes zero?
Message 5 of 34
(9,562 Views)
These initial conditions are relative offsets to the results of each of the integral operations, ie
The result of the integration of the acceleration signal is your velocity distribution, which is relative to the initial condition 0.2 to t=0.
The result of the intergration of the velocity distribution is your displacement distribution, which is relative to the initial condition 0.3 at t=0.
Therefore, just add the initial condition to the distribution.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 6 of 34
(9,560 Views)
Thanks a lot
But I tried it and got a problem that the displacement signal is drifting downwards. It should be a sine wave but it is not coming like that. Please see the attached VI file for details. Here acceleration signal is of 1Hz frequency. Pic.JPG
Message 7 of 34
(9,471 Views)
Hi Sehgal,
did you read my message #4?
Message 8 of 34
(9,469 Views)
Of course it is. If you intergrate a sinusoidal signal with a non-zero meanline then you will see shifted result biased towards that meanline. Therefore, if the centre plot has a meanline of -0.159 (as dictated by the initial condition), then the integral result will slope downwards. This is an expected outcome.
Message 9 of 34
(9,465 Views)
Hi GerdW
I have tried that also but the same problem persists......the double integral drfits downwards as shown in the third scope
Can you please send the VI file to me...I will be very thankful to you....i have already spent 50 odd hours on this problem.
Please help
Message 10 of 34
(9,464 Views)
