accessing Matlab functions
Is it possible to access Matlab functions (m-files) in Labview.
Is there a dll that fixes the problem?
I don't know how to calculate feedback gains using the lqr-algorithm and
kalman and that sort of stuff...
Toon
(3,086 Views)
Under LabVIEW 5.1 and higher, there are a number of excellent additional
Mathematics functions built into the palette, including a Matlab script formula
node. If you've got LabVIEW 5.1 under 32-bit Windows, you can simply pop one of
these nodes down on your diagram, right-click it to import your m-file, and
you're all set.
Depending on your OS and your versions of LabVIEW and Matlab, there will
probably be additional possible ways to communicate between the two
applications, but if you're doing a lot of Matlab integration, LabVIEW 5.1 is a
good investment.
John Lum
> Thanks
> Toon
(3,086 Views)
