acquire sound waveform 2 channels
Hello guys!!
I would like to plot the waveform from a sound of my sound card (using the microphone).  Well, with the "acquire sound" icon from the Express menu I could make it.  But I have a trouble when I want to store as a binary data.  If a set the "acquire sound" icon in 1 channel, I have not problem to store and plot then, but when I set the "acquire sound" icon in 2 channels, I can to plot the binary data.  I attach a picture with the vi
Can someone help me please?
thanks
Message 1 of 10
(5,140 Views)
How are you running your VI? Are you using the 'Run Continuously' button?
Cory K
Message 2 of 10
(5,129 Views)
No,  I am just running my vi with "run" button
by the way, I am a phisicyst from the Universidad de Santiago de Chile (USACH)
thanks
Message 3 of 10
(5,121 Views)
I wouldnt recommend the Express VI.
You just need to do something like this:
Only the Read needs to be in a loop.
Remember to put a wait in the loop.
The data output is an array of waveforms, so you can write to a file if you want.
Cory K
Message 4 of 10
(5,120 Views)
Thats cool! MSU's physics department collaborates with some physicists in Chile with the SOAR telescope
Cory K
Message 5 of 10
(5,117 Views)
Sorry, but it is not the problem.  I only have been using the "acquire sound" cause I need to simulate severals channel and then can to store in a unique binary file with two columns.
Message 6 of 10
(5,105 Views)
Are you having a hard time with the graphing or the writing to a file?
Cory K
Message 7 of 10
(5,102 Views)
I think you should modify the "Sound Input Read VI" as shown in the picture. Remember to save it some place else than the vi.lib dir
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 8 of 10
(5,095 Views)
Sorry guys, maybe I made the wrong question.  I just used the "acquire sound" to simulate several signals.
What do you think about this solution???
Message 9 of 10
(5,063 Views)
Accepted by nomade42k
Very close to ending up here
http://forums.ni.com/ni/board/message?board.id=BreakPoint&thread.id=2634&view=by_date_descending&pag...
try to understand this
Do NOT use Express VIs. Using Express VIs is like peeing in your pants a cold winter day. You may get warmer for a few minutes. But after that it will be very cold.
Message 10 of 10
(5,060 Views)
