activeX event
I'm trying to use a calendar ActiveX http://shareme.com/details/calendar-activex-control-sdk.html
In the help :
OnDayClick
  Occurs when you click the day box.
void Calendar1_OnDayClick(ByVal iYear As Integer, ByVal iMonth As Integer, ByVal iDay As Integer, ByVal strText As String)
Parameter
iYear - the year you selected.
iMonth - the month you selected.
iDay - the day you selected.
strText - the day text if available.
Return Value
 No return value.
Example
Visual Basic Syntax
Private Sub Calendar1_OnDayClick(ByVal iYear As Integer, ByVal iMonth As Integer, ByVal iDay As Integer, ByVal strText As String)
txtCurDay = iDay
txtDayText = strText
End Sub
But I really have no idea to implement this !
I just want to have the date when I click on the calendar !
Any Idea ?
V-F
Message 1 of 10
(4,908 Views)
As a starting point you can give a look to this thread (there are examples for the MonthView calendar ActiveX)
http://forums.ni.com/ni/board/message?board.id=170&thread.id=327119&view=by_date_ascending&page=1
Marco
Message 2 of 10
(4,897 Views)
An example on how to get the selected data from the control:
Message 3 of 10
(4,891 Views)
Hi all,
thanks for your answer.
If i chosed this activeX, it is not a hazardous choice. This calendar has options that a classic month calendar doesn't have.
My question is how to use THIS ActiveX, and not an other solution.
Thanks.
V-F
Message 4 of 10
(4,885 Views)
Hi ramses64,
  Before using that activex control you need to activate it..For that you need to buy it..
Thanks and regards,
srikrishnaNF
Srikrishna
Message 5 of 10
(4,878 Views)
Are you sure ?
There is a pop up which says it is a demo version, and I think that I can test it before purchasing !
V-F
Message 6 of 10
(4,876 Views)
 Have you put the activex control on the front panel...?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 7 of 10
(4,869 Views)
yes, of course, and I worked with it, but no idea how to read the selected data.
V-F
Message 8 of 10
(4,864 Views)
Accepted by ramses64
I found the solution with callback event.
Labview is fantastic... 🙂
Thanks to all.
V-F
Message 9 of 10
(4,850 Views)
Hi ramses64,
  I think you have proved once again... :smileyvery-happy:.
  BTW please post your vi.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 10 of 10
(4,838 Views)
