adaptive contro theroyl
In the VI provided, the stimulus signal (PID output) goes into the same model created initially, so there is no way that you will get any model changes by system identification (besides that from errors regarding the algorithm used for identification).
cosmin
Message 21 of 28
(1,440 Views)
There are a few things I notice-
1. You are doing some seemingly unneccessary conversions. You have a state-space, convert it to a transfer function and then pass that to a discrete transfer function. Is there a reason you are doing this over using the "Discrete  State-Space" function directly - such that you will not need to convert to a transfer function?
2. You didn't provide us any of your front panel control values. What are you using for A, B, C, D, sampling time, PID gains?
--Michelle
Message 22 of 28
(1,406 Views)
hi
is there a way to communicate directly with NI engineers
or any one with experiance in control ??
Message 23 of 28
(1,392 Views)
One last thing that I missed is that you are not properly converting your model from ARX model - this could certainly cause an issue.
24604iA43D792EEAB5F4A6
The correct way to do this is to replace the unbundle and the CD Set Data to Model and replace it with SI Convert to Models of CDT:
24606i53C44D0FC0380257
Please try this, even if this isn't the root cause of your issue, it is something worth changing as it could be causing other problems.
--Michelle
Message 24 of 28
(1,368 Views)
thanx alot for your help
Message 25 of 28
(1,351 Views)
You're welcome. Smiley Happy Hope that helps.
--Michelle
Message 26 of 28
(1,341 Views)
IM JUST WINDERING IF THERE IS ANY WAY TO GET HELP LIKE AN ONLINE HELP FROM NI ENGINEERS , CONTROL AND SIMULATION
Message 27 of 28
(1,329 Views)
Hi aswwwa,
I'm not aware of a way of directly speaking with an NI Engineer online, but you can try to call into technical support.  Find more information at ni.com/support.
Jared S.
Applications Engineering
Message 28 of 28
(1,257 Views)
