‎01-05-2006 11:51 AM
‎01-05-2006 04:17 PM
HI,
I think what you are tring to do is done with Tools >> Options..>>> Controls/Functions Palettes. Then under Palette Loading, select Load Palettes when needed.
The way I understood it, this is a way to optimize LV loading. For the use case where you have lots of VIs in a networked dir, the user may never look in that sub-palette, so why wait for labview to load a palette that may not be used... So, the Load When Needed option only looks for the contents of a palette when you click on the palette.
I tried in LV 7.1, and the feature didn't work. I launched LV, moved a new VI into a the user lib, then went to the diagram, and selected the user lib palette. The palatette contents did not show the VI that just moved over. I also tried with a customized palette that had a special new custom sub-palette, and it didn't work.
If you have LV 7.0 (or LV 8), try the steps at the top. If it doesn't work then it may be a bug, or it may be difference between expected functionality, and actual functionality. The help on the Controls/Functions Palettes leads you to believe that "Load palettes when needed" will do what you are looking for.
let me know of you have any questions.
J
‎01-05-2006 04:28 PM
‎01-05-2006 04:49 PM
LabVIEW, C'est LabVIEW
‎01-05-2006 05:02 PM - edited ‎01-05-2006 05:02 PM
Message Edited by T_M on 01-05-2006 05:03 PM
