adding arrays
I am looking for a vi that I will be able to add all the elements in a large one dimensional array (hexidecimal format) and come up with the value (hexidecimal).
Mark
(3,750 Views)
Look in the Numeric palette...you should find the "Add Array Elements" function.  On the indicator you wire to this function, choose Visible Items > Radix, and change the radix from decimal to hex.
-D
(3,746 Views)
Thanks but I did not explain myself fully ....
I have strings in hexadecimal format in this 255 string array. I would like my outcome to be converted back to this string function. I am looking to just send my full array in an get the element out.
(3,743 Views)
This should do what you need. You'll find the conversion functions in the "String>String/Number Conversion" function palette.
Ed
Message Edited by Ed Dickens on 04-11-2006 10:00 AM
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,740 Views)
Thanks that is exactly what I was looking for
(3,732 Views)
