an error occurred while installing a package: ni-pcibrd
guys please can you help me with this error message? i can' t understand how to bypass this... help me solving pleaseCattura.JPG
Message 1 of 8
(5,388 Views)
this document covers installation issues similar to yours. I suggest you try the listed solutions, in particular using the offline installer (if you have used so far the online installer, i.e. the 5 MB file that requires an internet connection to download all the necessary packages).
Hope this helps!
Alessia
Message 2 of 8
(5,333 Views)
thank you for the tip, i am now installing the offline installer and i am going to try that installation...
Message 3 of 8
(5,325 Views)
unfortunatelly i tried with that offline type installation but nothing new happened...
Message 4 of 8
(5,314 Views)
Have you tried also the other steps in the Solution section of the document above?
If so, I ask you to send in attachment the NI Package Manager error logs as described in this other document.
Alessia
Message 5 of 8
(5,309 Views)
Accepted by topic author dedderedemi
thank you so much for supporting me.
thanks to another operator too  i finally solved my problem.
we unchecked some driver installers and we updated all softwers in ni package manager and finally it worked.
Message 6 of 8
(5,281 Views)
Hello I have the same error that you can tell me how you solved it?
Message 7 of 8
(4,156 Views)
I got the same error message.
Is there any solution for that?
Message 8 of 8
(1,099 Views)
