any way to use property nodes for indicators in a cluster?
I have a vi that had 4 waveform charts in a cluster. I wanted to use a
property node to clear them, but couldn't figure out how to get it to act on
the cluster or on the graphs in the cluster. I ended up abandoning the
cluster and just having 4 graphs seperate, but is there any way to do it
within the cluster?
(2,728 Views)
From the Front Panel, "right-click" the desire indicator, from the pop-up menu, select create Property Node.
Now, you should have a Property Node of a indicator within a clustor of indicators.
Same apply to clustor of controls.
Regards
ian.f
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,728 Views)
> within the cluster?
If you popup on the front panel control/indicator within the cluster you
can make a property node for the individual item. Write an empty array
to the history property of a chart and it is cleared.
Greg McKaskle
(2,728 Views)
