append
Hi there,
So my string has a data size(hex code) of 117824. Now I want to make it of size 118784 so that it is perfectly divisible by 4096. So basically what I want to do is add zero paddings to the empty strings until it reaches 118784. I tried using replace substring but couldn't get the expected results. Thanks!append.PNG
Message 1 of 14
(5,644 Views)
I tried using this approach instead but the output was 3030 3030 3030. What I wanted is 0000 0000 0000.
Message 2 of 14
(5,630 Views)
Hi keatwk,
when you post images of your BD you should really use Ctrl-U before…
Padding a string can be quite easy:
That's because you don't know the difference between a byte with value zero and the ASCII char "0"…
Message 3 of 14
(5,617 Views)
Hi GerdW,
May I know why are you using case structure? Also could I have the vi file (preferably in 8.5). Thanks!
Message 4 of 14
(5,588 Views)
Hi keatwk,
No need to add 4096 bytes in case the string already has a proper length…
Unfortunately I didn't save this little item. It's easy enough to recreate it from scratch - and a nice exercise for you to learn LabVIEW with…
Message 5 of 14
(5,574 Views)
@keatwk wrote:
Hi GerdW,
I'm assuming the case structure is for readability.  Initializing an array of "Remainder" number of elements and concatinationg that too string should work just as well without the case structure.
Backsaved to LabVIEW 8.5 attached
Message 6 of 14
(5,565 Views)
My data are in ASCII formats, so inputting 00 doesnt give out 00 hex code. But when I tried inputting "NUL" it gives out something else too. How can I go about this?
Message 7 of 14
(5,539 Views)
Hi keatwk,
did you notice the display mode of the string constants in my and Jeff's example image? There's a reason why we explicitely show this setting!
@Jeff: Is there a reason to add 4096 bytes to the string when it happens to have a length dividable by 4096?
Message 8 of 14
(5,533 Views)
This looks like it is related to this thread here
http://forums.ni.com/t5/LabVIEW/split-hex-code-after-every-4096-bytes/td-p/3212543
If you look at my example that I posted you end up with 4096 bytes padded already in one operation...
Craig
LabVIEW 2012
Message 9 of 14
(5,524 Views)
Hi keatwk,
to make it more easy to understand the code and to get the zero bytes you need to pad your string try this:
Message 10 of 14
(5,514 Views)
