array column extraction
Hello
How can i extract different column (combinations) from an array.
I would like to have a 3 boolean array and would like to extract column 1 and 3  by pressing boolean 1 and 3 to ON state.
Message 1 of 8
(6,079 Views)
You can do something like this. Use boolean array to number to select different cases.array selection.png
edit:
didnt want to confuse you with array selection, changed the booleon array.  Arrays start at 0 so if you wanted 1 and 3 it would look like this.
-Matt
Message 2 of 8
(6,055 Views)
Thank you so much. It works great apart from the fact that i have to create 8 cases, which would be a problem if the size of my boolean array increases?
Is there a solution for that?
Thanks again
Message 3 of 8
(6,034 Views)
Here is another option if you want maintainability on it.
-Matt
Message 4 of 8
(6,027 Views)
You may also need a transpose array if you want the final array to be set in columns, since build array will create new rows.
Message 5 of 8
(6,025 Views)
I guess conditional autoindexing has been made exactly for this purpose... No case, no build array, no shift register. My 2011 can not make them, so I can not show...
Message 6 of 8
(6,005 Views)
Accepted by topic author zezendapuss
Very true,
Here is a cleaner example using alexander's suggestion, if you have the conditional tunnel mode available.
-Matt
Message 7 of 8
(6,000 Views)
Slightly different variation.
Message 8 of 8
(5,994 Views)
