array from while loop
How can I obtain the array from the while loop in the attachment?
Any help will be appreciated.
[Running LabView 8.5].
hiNi.
(3,034 Views)
Accepted by hiNI
What do you mean by "obtain an array"?  You are getting an array which will have a random number in the 1st element and the number 10 as the second element.
Are you trying to build an array of values that contain information from all the iterations?  Then right click the tunnel and turn on auto-indexing.
(3,031 Views)
I am trying to get an array of the values that contain the information from all the iterations and you have solved my dilemma.
THANKS!
(3,028 Views)
