automatic system standby generation and resume after few seconds?
Lol, Smiley Happy U are my hero Smiley Wink
Am out of time now. Smiley Surprised ill check this tomo and catch up u then Smiley Very Happy
Mathan
Message 11 of 47
(1,535 Views)
Dears,
I have tried this. (powrprof.dll under c:\windows\system32\)
What happened is the system just got restarted and it seems it didn't entered suspend mode. Also the attached popup error message appears.
Also i want to know how to wake up from the suspend state and resume to normal state?
Mathan
Message 12 of 47
(1,518 Views)
Hi mathan,
see the attachment please, it works for me. Smiley Happy
Mike
Message 13 of 47
(1,512 Views)
Dear mike,
Yes. Its working great. Thanks. Smiley Happy
As smercurio told i looked into kernel32.dll for createwaitabletimer and setwaitabletimer functions. But not got any clear idea. Even not able to understand what the function does (Better MSDN may explain in bit detail).
Mike,,,, is it possible to automatically resume the system from the standbymode without any disturbances like mouse move or key press or anything.
Any suggestions????
Mathan
Message 14 of 47
(1,508 Views)
Dears,
I have connected a USB device to my system. I used parallel port to control the power of the device.
My USB device got switched off when systems enters standby mode.
What am asking is when the system enters suspend state, the parallel port signals will get changed?
Mathan
Message 15 of 47
(1,502 Views)
Hi mathan,
i can create and set the timer, but it don´t work on my pc. Maybe you have more luck with it. Smiley Happy
Mike
Message 16 of 47
(1,494 Views)
Dear mike
Lot of thanks. I will give a try and update soon.
Mathan
Message Edited by mathan on 05-16-2008 04:18 AM
Message 17 of 47
(1,493 Views)
Dear mike,
I tried with ur vi. what i observed is, standby happens immediately Smiley Happy when i run the vi and
its seems wakeup is happening Smiley Very Happy (caps-lock and scroll-lock LED's at the top right corner of the keyboard got reset and it blinks which indicates the wakeup of the system).
But, the monitor still remains off Smiley Mad and only with external interrupts like mouse move or key press only it enters normal screen view. Smiley Sad
Any comments?
Mathan
Message 18 of 47
(1,490 Views)
You should be aware that Standby and Hibernate do not always work as advertised. Perhaps you should consider a more full-proof method of whatever it is that you're trying to accomplish.
Message 19 of 47
(1,479 Views)
Dears,
Am trying to develop a automated testing application using LabVIEW for testing my USB device.
In one round of testing, i need the system to automatically enter into standby mode (which was now possible by the help of you guys) and after particular seconds will have to wakeup again. This needs to be automated.
Is this one possible? If so how to achieve this?
Mathan
Message 20 of 47
(1,472 Views)
