automatic system standby generation and resume after few seconds?
But you could use the vi´s also without them, right click on the control/constant/indicator and select "disconnect from typedef". Smiley Happy
Dear mike,
Daily am learning lot of things from you. Thanks a lot.
Mathan
Message 31 of 47
(1,200 Views)
Actually i thought of simulating a key press or mouse click automatically (programmatically) after the system enters resume state.
[Edited: I thought this because my systems gotback to resume state without any problem but monitor only needs external disturbance to get activated]
Nope. The idea didn't worked. I tested with some 3 test machines, but same problem pursues. Any suggestions?
Mathan
Message 32 of 47
(1,195 Views)
Hi mathan,
when do you simulate the key press event? After the pc resumed?
I think while the pc is in standby mode, it is not possible, but maybe after.
Mike
Message 33 of 47
(1,193 Views)
Hi Mike,
c the attached.
That subvi named 3 was the keydown.example.vi
Message Edited by mathan on 05-19-2008 06:31 AM
Message 34 of 47
(1,191 Views)
Hi mathan,
i think the problem is, that after suspend nothing run anymore. If you are really sure your pc come back after a specific time, you can run a vi in background with an endless loop and see if it begins running after coming back. If yes you can send the simulated key maybe with this vi.
Hope it helps, and clear what i mean. Smiley Happy
Mike
Message 35 of 47
(1,185 Views)
Hi mike,
That's a first class idea. I will try this on another few systems and update soon.
Mathan
Message 36 of 47
(1,183 Views)
You are always very clear Smiley Happy and clever Smiley Wink in explaining things. Smiley Very Happy
Mathan
Message 37 of 47
(1,180 Views)
Well, if nothing else, you two are definitely getting each other's posts count up with the number of threads in which you guys go back and forth. Smiley Very Happy
Message 38 of 47
(1,165 Views)
Hi smercurio...,
yes that´s right, and the only reason why i´m here. Smiley Mad Smiley Wink
Mike
Message Edited by MikeS81 on 05-19-2008 04:05 PM
Message 39 of 47
(1,159 Views)
But the thing is the problem is getting solved with nice suggestions. Also whoever hereafter facing such kind of problems will get clear understandings from this post. Smiley Wink Ok? Smiley Surprised
Mathan
Message 40 of 47
(1,157 Views)
