automatic system standby generation and resume after few seconds?
I think you guys misunderstood/misinterpreted the intent of my message. Chill out. It was not meant to be derisive.
Message 41 of 47
(930 Views)
Ooops Smiley Indifferent smercurio thanks a lot. Smiley Happy I was afraid you are scolding us. Smiley Wink
Threads should have such encouragement messages to boost others Smiley Very Happy
Mathan
Message 42 of 47
(923 Views)
Dear smercurio,
where are you from? Your English was so good.... Smiley Happy
I saw your High Class English words in lot of threads.... Smiley Wink
Thanks, Smiley Very Happy
Mathan
Message 43 of 47
(917 Views)
MikeS81 wrote:
i think the problem is, that after suspend nothing run anymore. If you are really sure your pc come back after a specific time, you can run a vi in background with an endless loop and see if it begins running after coming back. If yes you can send the simulated key maybe with this vi.
Dear mike and smercurio,
Am damn sure, my system got wakeup after an user input delay. But still the monitor didn't get switched ON.
Which dll is controlling the power of the monitor? If we know that, then its easy to solve my problem. any ideas? Thanks....
Mathan
Message 44 of 47
(881 Views)
Hi mathan,
here is an example how to switch on and off the monitor.
Hope it helps.
Mike
Message 45 of 47
(875 Views)
Mike,
This is what i did but still monitor sleeps. In this case, the monitor is getting powered ON (LED at the bottom turn from orange to green), but the window screen didn't get loaded, instead just black screen persists. With the press of a key or mouse move only it getback to its normal screen.
Any issues?
Mathan
Message 46 of 47
(869 Views)
Hi mathan,
as i said in a previous post, did you check if this vi already run if the pc came back from suspend? i´m not sure about it.
You only need the "Monitor ON" part. Smiley Happy
Mike
Message Edited by MikeS81 on 05-26-2008 02:35 PM
Message 47 of 47
(867 Views)
