axis font size in labview
Hi there,
How do I increase the font size of the axis labels of plots in labview? can this be done?
(5,256 Views)
are you talking about a graph?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(5,255 Views)
Yes, an XY graph or the waveforms
(5,251 Views)
Accepted by GEEK777
Right click on the graph. Advanced.  Customize.  You can pick the label and change the font, size, and style based on the font picker on the toolbar.
Programmatically you can do it by a property node of the graph.  X scale >> Name label >> Font >> All elements or the individual properties.
(5,240 Views)
Can this also be used to change the fonts of the numbers on the axis?
(5,235 Views)
Yes.  It would be X scale >> Marker >> Font >>  All elements or the individual property for those.
(5,231 Views)
