build a replace array subset
Hello
I want to build a replace array subset but I can't.
I tried defferent methods to create it with no success. My question is where to put it in my program, what to insert as an n-dimension array and how to connect the index and my new elements in the true and the false case.
The size of the array i want to be 1x24, the index comes from a counter, the new elements are a result from a for loop in a case structure. They are all enclose in a while loop. The case structure for the for loop and the counter become true every 2 minutes.
Here is a photo of my program.
Regards
(3,566 Views)
hi zaxos,
  "I want to build a replace array subset but i can't"..This sentence i am unable to understand... :smileysad:...But i can tell you that ifyou want to use the replace array subset .then you should have an initialised array.This initialise array can be done using initialise arry with input as 0 and length as some 500...
Thanks and regards,
srikrishnaNF
Srikrishna
(3,556 Views)
Hello srikrishnaNF
I tried that method with no success, i put the initialized array outside the while loop but every time that a new element insert the array is initializg again except the index of the last time, the photo is for that case. I hope you understand what is my problem. Do you have any idea where to put the initialized array to avoid this situation?
Regards
(3,544 Views)
Accepted by Zaxos
That's a common problem. Every time you loop you start with the same array, thus getting the behaviour you describe. To fix it, change the Initialized arrays connection to the loop to a Shift Register and feed the replaced array to the output side of the SR. The SR feeds the newly changed array to the next loop, which i bet is what you want. 😉
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,533 Views)
