build error using daqmx vi's crashes LV
I am trying to build an executable in LV 8.2 (it worked in 8.0) using daqmx create channel.  The build is not successful and sometimes gives no reason and other times tells me to allow debugging.  I allow debugging and the executable tells me I need full development to fix error.  I should be running professional development.  Sometimes I get a LV crash where LV has encountered a problem and needs to close.
(2,364 Views)
brianpt,
Thanks for posting to the NI forums.  Do you still have issues if you try to build an application that does not contain any DAQmx code?  What version of DAQmx do you currently have installed?  What is the exact error that you are seeing?  Are you using the LabVIEW Professional Development system?
Neil S.
Applications Engineer
(2,353 Views)
