I am trying to build an executable in LV 8.2 (it worked in 8.0) using daqmx create channel. The build is not successful and sometimes gives no reason and other times tells me to allow debugging. I allow debugging and the executable tells me I need full development to fix error. I should be running professional development. Sometimes I get a LV crash where LV has encountered a problem and needs to close.
