building applications with motion control
I've created a program that uses motion control and digital I/O via the PCI-7344 Motion Control card.
It works fine in the LabVIEW environment but ignores does not perform any action that uses the motion card.
I am not creating an installer for the program and I am trying to run it on the same machine that has the development environment.
The only thing I can think of is that I'm feeding a setting name into the Intialize Controller.flx vi.  maybe it needs a path?
Am I overlooking something obvious?
Charlie
(2,942 Views)
Hi Charlie,
Are you using the Motion Error Handler.flx for the motion portion of your code?  The reason I am asking is LabVIEW's simple error handler will not return motion errors.  It is possible that an error is occurring, but we are not catching it.  If you are not using the Motion Error Handler.flx try using this and we should be able to determine the problem.
Ryan M.
Applications Engineer
(2,930 Views)
Accepted by asuwish4
Hi Ryan,
It's now solved actually...  It turned out that I needed to add the following to labview.ini:
BldApp.RemovePolyVIsandTypedefs=False
Thanks!
Charlie
(2,922 Views)
Glad to hear it is working now.
(2,912 Views)
