button to increase slide
Please, how can I create a button to increase, and decrease a slide ? Thank you, Juscelino
Message 1 of 9
(5,001 Views)
What do you mean by this request? I am not sure if you want buttons that will increase the value of the number displayed by the slideder or you want to make the minimum and maximum change.
Tim
GHSP
Message 2 of 9
(4,992 Views)
You can use an Event Structure with a Local Variable.  I added the In Range and Coerce check to prevent going beyond the limits of the slide.
Jim
Message 3 of 9
(4,968 Views)
Please,what is the name of this icon between unbundle by name and  the  slide ?
Thank you
Juscelino
Message 4 of 9
(4,952 Views)
In Range and Coerce
That image is a Snippet.  You can drop it onto your Block Diagram if you're using LV2009.
Jim
Message 5 of 9
(4,950 Views)
could you help me?
My VI only increase but not decrease the slide.
two events are ?
where is the difference between the increment event and the event decrement ?
I am sending the vi.
Thank you
Juscelino.
Message 6 of 9
(4,928 Views)
Hi Juscelino,
"two events are ?"
Don't know what you say here...
"What is the difference..."
The point is: both are same (more or less). When you want to decrease a value you should use a subtract instead of a add function... Just use proper debugging using the highlighting tool!
Message 7 of 9
(4,924 Views)
solved. thank you very much.
Juscelino.
Message 8 of 9
(4,921 Views)
I adjusted your code Try this. I have both increase and decrease in the same event. There is no reason to have both.
Tim
GHSP
Message 9 of 9
(4,918 Views)
