cómo puedo hacer el siguiente caso en Labview?
::hivemind::
Message 11 of 20
(1,324 Views)
He hecho lo que esta en el VI adjunto... pero la verdad no sé mucho.... Me puedes guiar más?
Message 12 of 20
(1,320 Views)
Cuál sería la condicion para la estructura case?.... Qué debería preguntarse allí?
Message 13 of 20
(1,316 Views)
Adjunto un nuevo .VI... he avanzado algo, miren que tal voy, espero más sugerencias y ayudas
ayudenme por favor
Message 14 of 20
(1,312 Views)
Could you save for LV2010?
Message 15 of 20
(1,308 Views)
Yes friend...There are.
Thanks. The block "string " is for message in text for User. For example no to guess a number
Message 16 of 20
(1,306 Views)
Something like this?
Your VI does not even run. Please try a little harder. We are here to help not to solve any school assignments.
As posted before you are encorauged to view the tutorials of 3 and 6 hours.
Please use the given enum as a starting point. Note that enums when use with case structures are quite handy.
Use the "select" function to decide to which case to proceed according to a boolean result.
As example:
Is the user number equal to the random number?
No (false), pass the state "failed guess"
Yes (true), pass the state "Correct guess"
Good luck
Message 17 of 20
(1,303 Views)
If i try to open the file main.vi; labview password request
Message 18 of 20
(1,301 Views)
I can`t open the file "Main" because have a password request. Why?, Who do for get a password?
Thanks.
And in the other file i can´t  to open block diagram
Message 19 of 20
(1,290 Views)
The second file is a control file.  It defines the typedef of the state machine enum.  It does not have a block diagram.
For the first diagram, I'm going to assume that he password protected the file so that he can give you a demonstration that it can be done and how it would work without actually doing your homework for you.
Have you done any LabVIEW tutorials yet?
Message 20 of 20
(1,288 Views)
