cRIO not loading a usb3 camera properly
 wrote:
Did you try installing the USB Webcam support?
Jordan
Stupid question how do I install the webcam support?
Message 11 of 16
(1,004 Views)
  1. Go to NI MAX and find your cRIO under Remote Systems.
  2. Expand the cRIO, right-click on Software, and select Add/Remove Software.
  3. In the software installation wizard, choose Custom software installation.
  4. Choose the components that you want to install. You should see USB Webcam Support in the list as shown in the screenshot in my previous post.
  5. Continue through the wizard to install the software.
Message 12 of 16
(992 Views)
There is not selection for USB Web Cam Support
Message 13 of 16
(986 Views)
On the previous page you need to select custom software installation.
2018-06-14 12_57_56-LabVIEW Real-Time Software Wizard_ NI-CVS-1458RT-01990B0E (10.1.128.246).png
Message 14 of 16
(982 Views)
Found it. The installation didn't change anything though, the camera is still appearing as a USB device
Message 15 of 16
(978 Views)
Accepted by topic author atokad
Hate to say it, but in that case you probably can't use this camera on the cRIO. Do you have to use this camera? If not there are other cameras that are compatible with the cRIO. Or could you use the camera on a PC?
Message 16 of 16
(973 Views)
