calculate color mask
Hi alexderjuengere,
Definitely .
Thank you
Message 11 of 31
(2,431 Views)
Kudos would be nice Smiley Wink
Message 12 of 31
(2,423 Views)
Hi alexderjuengere,
                               Can you please send me the labview.vi file for the segmentation(color mask file).
THank you
Message 13 of 31
(2,408 Views)
you can use the .png snippet via drag and drop!
http://www.ni.com/white-paper/9330/en/
Message 14 of 31
(2,403 Views)
Hi alexderjuengere,
                              When using k-mean clustering to find the dominant color in an image,for example,if i had given classes as 5,in the array there will 5 colors as output,each time when i execute the code with the same input image file,the colors in the array changes.Do you have any any solution for this or any other method to find the dominant color?.
I have attached the image regarding the change in color in the arrax color while executing the same input image for various time.
Thank you
Message 15 of 31
(2,387 Views)
hi madhubalan,
k-means in a nutshell:
1. Ask user how many
clusters (classes) they'd like.
(e.g.. k=5)
2. Randomly guess k
initial cluster center
locations
3. Each datapoint finds
out which Center it’s
closest to. --> classification!
4. Each Center finds
the centroid of the
points it owns...
5. ...and jumps there
6. ...repeat until
terminated
compare: http://www.autonlab.org/tutorials/kmeans11.pdf
one quick solution:
have you tried to reduce the number of classes?
K-means is an unsupervised learning technique.
A k-means algorithm works best, if the initial cluster centers ("ground truth" would this be called in supervised learning techniques) are decently guessed by the algorithm or "teached-in" by the user.
I haven't installed this clustering toolkit on this machine, but I think this double-array constant was related to those initial cluster centers:
If this constant is empty, there is an automated guess, I guess.
Alex
Message 16 of 31
(2,375 Views)
by the way, I prefer this machine learning toolkit, because it also got visualization in 2d (XY Graph) and 3d (3d picture controls)
Message 17 of 31
(2,371 Views)
The screw you want detect is evidently quite bright due to it's well-reflecting surface and the chosen illumination.
Total reflex ion causes rather white colors, so the 3 rgb values of those particular pixels will be rather on the right side of your brightness histogram graph.
Speaking of histogram graphs, you should do some exploratory data analyses on your input pictures: http://www.ni.com/white-paper/4158/en/
This will definitely help you to localize the range of your thresholds. Regarding to thresholds: I recommend to use more than one.
Segmentation is a tricky task with real world data.
Alex
Message 18 of 31
(2,355 Views)
Hi alex,
           I could not able to find any other method for dominant color determination.If you have any method ,then let me know it.
But ,if i use only class 1,then dominant color remains the same for many execution step for the given input image.
This the link for downloading the clustering tool.https://decibel.ni.com/content/docs/DOC-4063
I have attached a vi file for color mask,in this file,how to determine the percentage of dominant color present in the given input image.(i have attached a input image)
Thank you
Message 19 of 31
(2,338 Views)
and does this give you the expected result/color? are you fine with this?
now, this sounds to be trivial:
                                 number of dominant color pixel
dominant color in % = ---------------------------------------------
                                 total number of pixel
have you given a try to my previous post at:
http://forums.ni.com/t5/LabVIEW/calculate-color-mask/m-p/2472546#M756827
a will look into your example later this day
Alex
Message 20 of 31
(2,330 Views)
