calculate color mask
Hi Alex,
            Yes, i want to highilight the particular area(especially screw and other objects) in the given input image.
Matching means, when comparing the object in the obtained binary image output with the object in the given input image,the objects should be highlighted.
It is similar to the attached image.
Thank you
Message 31 of 31
(451 Views)
