calculate difference between time strings
I am using the Get Time/Date String.vi to report the time everytime data is taken. Is there an easy way to subtract one time string from another to calculate the time in between data measurements? I need this for excel reporting.
Any help is appreciated!
Message 1 of 17
(8,624 Views)
If you are working with strings, you will need to parse them to reconstruct timestamps, then its just a matter of subtraction. It would be easier if you could get at the time values before they are converted into strings.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 17
(8,619 Views)
I am still fairly new to programming so maybe this is a basic question but how would I go about parsing and reconstructing the strings?
Thanks!
Message 3 of 17
(8,573 Views)
Hi marcella,
to parse string you could use ScanFromString - in your case combined with formatting codes for time stamps as are explained in the help for that function!
Message 4 of 17
(8,564 Views)
For the heck of it I attached an example VI.  It takes two string controls, formats them into time stamps, and gets the difference in time between them.  The format for the time needs to be known and that is what the scan from string uses.  If your format is different that's fine, it will just need a string constant that corresponds to your format.
Message 5 of 17
(8,532 Views)
Hoovah shows how to find the difference between two time/date strings in Labview.
While that works I recommend you stop writing time stamps to an Excel file as a time/date string.
One of these days it is going to bite you in the behind, as you already have found you can not do any math on a time/date string once it is in Excel.
Instead of writing a time/date string you should write a double precision number that corresponds to the OLE date that Excel uses.
Now you will find when you open your Excel file the time column will look like a crazy number, simply format the column to the time and/or date format you desire.
You will find that you can now do a running subtraction to show the time between time stamps in Excel.
=== Engineer Ambiguously ===
Message 6 of 17
(8,524 Views)
Or just use these
RTSLVU, you missed the leap yer bug correction and, those constants would make more sense if the display format was relative timeSmiley Wink
Message 7 of 17
(8,509 Views)
@JÞB wrote:
Or just use these
I don't think I have ran into the Leap Year bug.
Does it just effect Febuary 29th?
Message 8 of 17
(8,503 Views)
If the text is properly formatted, Excel will automatically interpret it as a time or date, and you can then do math on it. For example, put the following text in a file, name it with a .csv extension, and open it in Excel, then try subtracting the two timestamps (you may need to modify depending on your local time format, but Excel is pretty flexible about interpreting times and dates).
4/19/2015 5:00 AM,25
4/20/2015 5:00 PM,30
The result will be 1.5 (or -1.5), since Excel treats days as integers, and times as fractions of days.
Message 9 of 17
(8,496 Views)
One thing I don't think Excel accepts in this format (correct me if I'm wrong) is fractions of a second.  If I try to enter 4/19/2015  5:00:00.123 AM the format is lost and weird things can happen.  It tries to recognize it as a number so some math still works but it no longer looks right.  Since we are often dealing with DAQ data and quick logging to a CSV it is quite often you'll have a sample more than once a second.  Other file formats like TDMS can log the raw time stamp data so there is no loss in precision.  In the past I've written TDMS files, then converted them to Excel to be more easily viewable.
Message 10 of 17
(8,488 Views)
