can't access Excel._Worksheet reference from NI_Excel.lvcass object
I am trying to access the "Excel._Worksheet" reference but when I use the "unbundle by name" I get a broken wire.  The green object is the NI_report.lvclass and the blue object is the NI_Excel.lvclass.
Not sure why I'm being prevented from getting the reference this way since I see this working as shown in NI_Excel.lvclass:Excel Rename Worksheet.
(I'm trying get the Worksheet reference so I can call the _Worksheet.Delete method.  I don't believe the Report Generation toolkit includes a Worksheet Delete VI.)
(I'm using LabVIEW 8.6)
-Joel
Message 1 of 9
(4,976 Views)
Accepted by Snood1
That's the incapsulation feature provided by LabVIEW classes, it protects the private content of the class. You can only unbundle in VIs that are parts of the class.
There is a VI that returns the application and document ref:
Excel Get ActiveX references
Ton
My LabVIEW Ideas
Message 2 of 9
(4,965 Views)
Ton
Adding to Ton's reply...
THe VI Ton showed you was omitted from the first release of the modified toolkit. We screamed so they added that VI to let us be creative. If you can't find that VI in your install, you will have to upgrade the toolkit.
Ben
Message 3 of 9
(4,961 Views)
To be a little more specific, you need to be running LabVIEW 8.6.1 with Report Generation Toolkit 1.1.4 to get this VI.  Or, of course, LabVIEW 2009 with Report Generation Toolkit 2009.
Message Edited by Darren on 05-20-2010 03:00 PM
Message 4 of 9
(4,957 Views)
Any technical reason why the toolkit 1.1.4 won't run on 8.6?
Ton
My LabVIEW Ideas
Message 5 of 9
(4,950 Views)
My mistake.  According to the Report Generation Toolkit 1.1.4 readme, you can use it with LabVIEW 8.6.
Message 6 of 9
(4,940 Views)
Thanks, everyone.  I am familiar with data encapsulation, but forgot that it would apply to labview classes too.  Smiley Surprised  I upgraded to RGT 1.1.4 so that I could use the "Excel Get ActiveX References" VI.  And yes, it works in LV 8.6!
Message 7 of 9
(4,928 Views)
Hi TCPLomp,
Thanks for the information!!
But does anyone have any idea how to get the class reference from the ActiveX reference. This is exactly opposite to what NI is offering.
I don't know how the NI engineers missed out this point when they can offer one way, so they could also offer it the other way too and that's what even I'm looking for. I've worked upon something like adding/inserting a new sheet in the workbook (NI library has it) but at the place that I choose (not at the end like NI Library does). Why can't these engineers think in advance or atleast gives us the option to modify the library for our use instead of just restricting like that. I just want to understand that. I feel MATLAB is flexible in this sense.
Thanks for your help!!
Manjeeth
Message 8 of 9
(4,224 Views)
Manjeeth,
In terms of getting the class reference from the ActiveX reference, try using a property node.
Also, I have attached a screen shot of a program that will allow you to specify where to add a worksheet.
Katie
Katie Collette
Message 9 of 9
(4,205 Views)
