can the dll built in Labview be called in labview
Hi
i built a Dll for the attached Vi and tried to call it in another vi. When i run this vi in which i called the dll, it exits the labview.
why is it so ?
(3,306 Views)
I have no problem in calling the DLL that's built. Did you specify the datatype correctly when you configured the Call Library Function Node? I've attached a VI that works.
(3,306 Views)
If you are returning a string try to populate the length input or include it in your code interface node and then populate it if you don't have it already. I noticed that if you don't populate that length LV will sometimes close on you. You will see if using a string output the length automatically added when you configure your inputs and outputs when building the DLL.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,306 Views)
sorry I meant your call library function.
BJD1613
Philips Respironics
(3,306 Views)
"Gops" wrote in message
news:50650000000800000075A30000-1042324653000@exchange.ni.com...
> Hi
> why is it so ?
Another possibility is a bug in LabVIEW 6.0. You need at least 6.0.2 to be
able to do that.
Rolf Kalbermatter
(3,306 Views)
I tried this in 6.1 and the same result that was described occurred.
BJD1613
Philips Respironics
(3,306 Views)
There are actually some common troubleshooting techniques for LabVIEW to LabVIEW DLLs that have been compiled into a KnowledgeBase. I would recommend taking a look at this KB at :
http://digital.ni.com/public.nsf/websearch/CFFFCA2248BC7E7E862569730059BDE5?OpenDocument
I hope these suggestions help. Have a great weekend!
Sincerely,
Liz Fausak
(3,306 Views)
