case structure problem with default 0, 1, 2
Good afternoon,
I have a question about the case structure. If you use 3 cases, default 0, 1 and 2, like in the following VI.
How can you fix that the sum is never 3? Because when you turn on the switch 1 and 2 simultaneously it gives the sum 3 and the case will go in the default stand.
Thanks for the help.
(3,679 Views)
I actually wants that it's not possible to turn on switch 1 and 2 simultaneously, so that the sum never is 3.
(3,665 Views)
I recommend changing to using an Event Structure.  That way you react to when a switch is toggled instead of constantly polling.
What I would do is, with the Event Structure, have a case for each switch's value change.  In the event case, you use a property node to set the Disabled property of the other switch based on the current switches value (Switch 1 goes true, so disable switch 2)
(3,660 Views)
Accepted by desley
Use a radio button. You can replace the standard buttons with your wide toggles.
Lynn
(3,658 Views)
Thanks a lot for the solutions Smiley Wink
(3,640 Views)
