catch event when digital signal DAQ input has falling edge
Hi GerdW,
Thank you for answering me, I checked back as you said. but it still doesn't work. I provide a square pulse with a frequency of 500mHz (very small). I input AI0 for a DC 5V signal to read.
Message 11 of 13
(654 Views)
Hi hung,
did you connect that pulse signal with PFI0 pin?
Can you connect with DIO0 in parallel and check for correct pulse signal here?
Message 12 of 13
(652 Views)
Hi GerdW,
I have checked many times, I have connected to PFI0 and trigger signal, I use both oscilloscope to check.
Message 13 of 13
(649 Views)
