centering GUI in LabVIEW
John,
You should be able to use property nodes.  A VI property can give you the FP.PanelBounds parameters which will tell you how large the panel is.  A panel reference can give you access to references to the decorations and controls.  Their Position and Bounds properties can tell you where things are.  You can then modify the appropriate properties to get the look you want.
Lynn
Message 11 of 18
(3,829 Views)
Building on Lynn's comment
Message 12 of 18
(3,824 Views)
jack47 - you did it!  awesome.
Message 13 of 18
(3,821 Views)
Thanks Nickerbocker, I think that was the most enthusiastic response to any code I have ever written.  All the posts seemed to be circling around that solution, of course they may be a better way to do it...
Message 14 of 18
(3,817 Views)
Nice one - much appreciated. Do you think I could group all the objects on my front panel and then use property nodes to set the position of the group? This would be easier than setting the position of every item individually.
Message 15 of 18
(3,794 Views)
You can try, I'm not sure how to get the reference to the group.  I tried grouping and moving the decoration, but the graph and boolean did not move.  One item, you can set the origin to the upper left corner to help incase someone drags the scroll bars around.
Message Edited by jack47 on 09-03-2009 03:56 PM
Message 16 of 18
(3,788 Views)
Accepted by topic author eichlerjw
right. Thanks to user "Ben" over here http://forums.ni.com/ni/board/message?board.id=170&thread.id=438359. He gave me the idea of use a tab control to group the items and then using property nodes to control the position of the tab control. Vi's attached.
What do you think?
J
Message 17 of 18
(3,759 Views)
I think that's a great solution.  The controls keep their location on the tab.
Message 18 of 18
(3,739 Views)
