change the color of square LED boolean
As title, I want the color of off form is transparent, but it does not display as my expectation.
I also tried to use color 4 of property node, but I fail.
How can I change the color? Can anyone help me?
Message 1 of 13
(4,943 Views)
Can you please state, what you are expecting and what is happening?
This is with same properties.
Message 2 of 13
(4,903 Views)
hi ,
You can change the color buy two Methods :
1 : using color [4]
2 :  using Properties
Message 3 of 13
(4,891 Views)
ufaruque123, Emna20 thanx for your responses!
Strangely, when I select transparent, the color become dark green in this boolean.
Besides,I expect that I can change the dark green to transparent.
Furthermore, in this case,I want to change the dark green to white without special effects.
Message 4 of 13
(4,878 Views)
hi antinhia ,
chek this vi ;
Kudos are welcome .
Message 5 of 13
(4,863 Views)
hi, Emna20
I find that my LabVIEW version is 2016 I can not open the file. > <''
Message 6 of 13
(4,861 Views)
You are using LabVIEW 2014.  This appears to be a bug for this control -- it appears to have been fixed by LabVIEW 2016 (the oldest system I currently have readily "at hand").  "Transparent" really isn't a color (it is a special value that LabVIEW "catches" and handles, but apparently the code was not implemented for Square LEDs at some point, including LabVIEW 2014).
Upgrade your version of LabVIEW and this problem should go away.
Message 7 of 13
(4,853 Views)
hi ;
if you want to change the color of the square LED from dark green to white  you have to use properties (colors : off) .
Message 8 of 13
(4,850 Views)
Accepted by topic author antinhia
Hi antinhia,
It looks like you have applied the color directly to the control.
You can fix by either of method,
Right click on the control and go to Visible Items--> Decal and un-check it
or
Select the paint brush and click it on the border of Boolean indicator(You can move the cursor at different part and observer the color) and set it as transparent
Or create a new control and don't apply the color on Boolean indicator using Tools (set color), set the on\off color using indicator properties as mentioned in another reply.
Message 9 of 13
(4,842 Views)
thanx you a lot Emna20!
yeah I know that I can change the color through Properties.
My ideal is the booleam only displays pure white without any special effect.
thanx Bob Schor! this is such a tangled bug, now I ignore it.
Message 10 of 13
(4,841 Views)
