chart absolute time
Hi, I lost my tick marks, Vertical grid and my date and times between the ends when I upgraded from Labview 6.1 to 2009.  I am plotting temperature over weeks at a time and I would like a tick mark and time and date to be displayed every 24 hours. I have tried everything to no avail
Message 1 of 9
(4,912 Views)
I wanted to let you know that most of this can be configured be the properties window accessed by right-clicking on the chart. Here are a couple screenshots that show locations of your requested modifications.
In order to change the length of time plotted by the chart, you can select "chart history length" from that same right-click menu.
Message 2 of 9
(4,863 Views)
Sorry I did not explain my problem.  See following.  The top is my chart using 6.1.  The bottom is my chart using 2009.  No matter how I format the X-Axis in 2009 I cannot get the time and dates to fill in as in 6.1.  Thank you for responding. I am looking forward to a fix. Thank you Ken
Message 3 of 9
(4,850 Views)
I don't think you got the pics all send as attachment.
Message 4 of 9
(4,841 Views)
That link generates an error.
Message 5 of 9
(4,839 Views)
Message 6 of 9
(4,834 Views)
Yes that should work but it doesn't in 2009 for some reason. The top chart is 6.1 bottom is 2009.  If I don't format for absolute time, everything is fine.
Message 7 of 9
(4,811 Views)
are you sure you have the x-axis selected.  Show a snip of the property page or attach the offending chart in a new vi
Message 8 of 9
(4,790 Views)
I have attached a vi with your suggested setting.  Could you please make this chart's X-axis look like the 6.1 chart and send it back to me.  I have searched many examples on your site and have not found one with the time and date "filled in" on the X-Axis.
Thanks for your help.
Ken
Message 9 of 9
(4,755 Views)
