chart - hot to display additional y scale in programaticaly?
hi,
        i am using chart with lv 8.6. i have bundled with 6 channels of data and connected with chart. i have to select my channels and according to display the y scale for each channels. this should be in programmatic way. how to do this?
Balaji DP
Message 1 of 11
(3,808 Views)
Hi Balaji DP,
can you explain a bit more?
If you need more than one y Scale then, afaik you have to manually copy the existing one. If you have as much YScales as you need, then you can select them with a property node.
Mike
Message 2 of 11
(3,804 Views)
Mike is right, you cannot create scales during execution, you can however hide them and select the scale for each plot at will:
Ton
My LabVIEW Ideas
Message 3 of 11
(3,790 Views)
You can also select the scale(s) to use while running by right-clicking the plot in the legend and selecting from the menu.
And, as you can see from the menu you can modify many other characteristics of the plots from this same menu.
LabVIEW 5.0 seems so long ago...
Message 4 of 11
(3,787 Views)
hi
i just want to add a y scale, for each channel . please find this attachment
Balaji DP
Message 5 of 11
(3,782 Views)
Not sure, but see if this functionality is what you wanted.
James
Message 6 of 11
(3,767 Views)
hi,
        can you send me chart1.vi as lv 8.6 version...?
Balaji DP
Message 7 of 11
(3,732 Views)
Accepted by Balaji_DP
Sorry for the delay, I've just been busy today.
Message 8 of 11
(3,707 Views)
Thanks Jones,
                        this is what i expected...
Balaji DP
Message 9 of 11
(3,689 Views)
Hi Jr,
If you add a litle text explaining what you are doing in code that you post without an image, you can still earn Kudos from the prowlers.
Without the text we are left wondering what was in that accepted solution or are forced to down load it just to take a peak. Do you really want to make the prowlers work that hard to determine if your post was good?
Ben
Message 10 of 11
(3,673 Views)
