choice of filter
hello
i've got a problem:
I receive a signal (you can see in the picture), and there is a lot of noise that I don't want.
how can I get rid of this noise
I already tried with some filter but it doesn't work.
Thanx for your answers
Ben
Message 1 of 22
(4,706 Views)
I forgot the picture
Message 2 of 22
(4,696 Views)
Are you measuring this signal using a DAQ card????
Rather than noise, from the pic it looks like a  0.34 V DC signal measured on a 12 bit ADC with input range +/- 10 Volts ( error of +/- 4.8 mV ):smileywink:
Is this correct??
Assuming this is correct, there are my suggestions to rectify this problem
One way to improve your measurement accuracy would be to choose an optimal ADC range ( Depends on the ADC ranges taht your DAQ card supports)
Or you could do a moving average on your samples to get a better readout
If this does not answer your query,  for a better answer please explain your situation more clearly Smiley Happy
Message 3 of 22
(4,688 Views)
Moving average with 3-5 passes or a Kalman filter should fix your problem.
Kudos are the best way to say thanks 🙂
Message 4 of 22
(4,673 Views)
thanks both of you.
devchandler, the signal comes from a DAQ-card but I can't say more because Idon't know more.
I just start my studies and I work in  Labwiev since 2 week to pay my room.
thanks Maximus00 but where can I find a moveaverage 3-5 or a kalman filter in Labview?
Message 5 of 22
(4,642 Views)
The quickest and easiest method:
Use express vi's>>signal analysis> filters
In the express vi, select filtering type as 'smoothing'
Message Edited by devchander on 09-26-2006 05:07 AM
Message 6 of 22
(4,633 Views)
thanks devchandler
that's much better i hope my boss will like that
Message 7 of 22
(4,621 Views)
benco:
i hope my boss will like that ,
you are hoping for the 'almost impossible'! Smiley Wink
All the best, benco!Smiley Very Happy
Message 8 of 22
(4,609 Views)
hey.......
my boss said that was not so goodSmiley Sad
so I tried and tried and....... and I discovered a filter named: Median Filter PtByPt
so this filter seems good, he makes what I want except theres is a response time ( dephasing?) that i don't want
I send you a picture
I noticed that when the filter rank is high the response time is high too but the graph seems good
but when the filter rank is small the response time is small too but the graph seems not good
i just want a mix of it .a beatiful graph and a small response time
Message 9 of 22
(4,597 Views)
do you have sample data that you can post ?  i have a bunch of filters so if u give me sample (if possible) i can play with it or i can give you some smoothing dlls that you apply on your data
Message 10 of 22
(4,593 Views)
