cluster output from VI?
So this is probably a very easy question to answer, but I can't seem to locate this information in any of the help files.
I'm trying to create a VI with inputs and outputs so that I can interface the VI with Signal Express.
Where can I locate input/output symbols to insert into my VI, which I then can connect to the connector panel so Signal Express can have access to the I/O of the VI?
I'm specifically looking for an output connector to be able to pass clusters out of my VI and into Signal Express. But any general help in this area is also appreciated.
Thanks.
(4,595 Views)
Accepted by david_i
To get the cluster output:
Click on the output of where the cluster is created (in this case a build cluster), then select create, and choose indicator.
To get a cluster in, you'd pick control.
Then just select it as you would any other indicator or control when assigning to terminals on the VI block icon.
(4,585 Views)
Thanks, it worked!
(4,571 Views)
