 david_i
			david_i
			07-25-2013 10:03 PM
So this is probably a very easy question to answer, but I can't seem to locate this information in any of the help files.
I'm trying to create a VI with inputs and outputs so that I can interface the VI with Signal Express.
Where can I locate input/output symbols to insert into my VI, which I then can connect to the connector panel so Signal Express can have access to the I/O of the VI?
I'm specifically looking for an output connector to be able to pass clusters out of my VI and into Signal Express. But any general help in this area is also appreciated.
Thanks.
Solved! Go to Solution.
 Hornless.Rhino
			Hornless.Rhino
			07-25-2013 10:32 PM - edited 07-25-2013 10:34 PM
To get the cluster output:
Click on the output of where the cluster is created (in this case a build cluster), then select create, and choose indicator.
To get a cluster in, you'd pick control.
Then just select it as you would any other indicator or control when assigning to terminals on the VI block icon.
07-26-2013 12:17 AM
Thanks, it worked!
